First PC build
Go to solution Solved by Azade12,
2 minutes ago, Downkey said:
If you are willing to wait for stock, then the 5600x will be a much better buy.
It performs better in
-Games
-Multithreaded applications
It will also be cheaper since the CPU + MOBO + Cooler combo is a lot less.
i think it’s worth waiting for stock. There are Twitter bots that give you audio alerts for when stock comes, and they come every couple days.
i think the 5600x is a better buy overall, but if you had to buy at this instant moment, then the 10600k is still a decent buy.
Yeah, definitely. AMD's the better buy for sure.
Budget (including currency): $1500
Country: USA
Games, programs or workloads that it will be used for: Games, auto cad and steaming.
Other details
hi everyone, my name is Kayden i am new to the group and looking for help to build my first PC
I'm debating on cpu between intel i-5 10600K or Ryzen 5600X.  I am not sure which one is best for my job please give me suggestions.
thank you!
https://linustechtips.com/topic/1293969-first-pc-build/
I'd go with AMD. They're more energy efficient and being more competitive in the CPU game. What GPU are you using?
AMD CPU's work consistently better especially when OC'd
RYZEN 5800X
ASUS B550M (WIFI)
GTX 1060 6G
3200 MHZ RAM
RM650 PSU
256G SATA SSD
1TB NVM.E SSD
3TB 5400 WD HDD
https://linustechtips.com/topic/1293969-first-pc-build/#findComment-14392630
Country: USA
Other details
thank you!
-Games
geometry is hard
b550 > x570
https://linustechtips.com/topic/1293969-first-pc-build/#findComment-14392631
-Games
RYZEN 5800X
ASUS B550M (WIFI)
GTX 1060 6G
3200 MHZ RAM
RM650 PSU
256G SATA SSD
1TB NVM.E SSD
3TB 5400 WD HDD
https://linustechtips.com/topic/1293969-first-pc-build/#findComment-14392634
thank y'all for suggestions.
I don't have to have  the PC right now so i would wait, AMD was the one i pick at first place. I also considered to get rtx 3060 for my build, and is B550 mother board is good for the build?
^-^ awesome!
RYZEN 5800X
ASUS B550M (WIFI)
GTX 1060 6G
3200 MHZ RAM
RM650 PSU
256G SATA SSD
1TB NVM.E SSD
3TB 5400 WD HDD
https://linustechtips.com/topic/1293969-first-pc-build/#findComment-14392655
Country: USA
Other details
thank you!
Made a little list for you.
You would have too wait for stock with the 3080 and 5600x, but I think this is a good list overall.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1293969-first-pc-build/#findComment-14392728
