CPU with no integrated graphics issue
Solved by mariushm,
Make sure you plugged in the CPU power cable, besides the 24 pin atx connector.
Debug the system by trying to power on just the motherboard+cpu+video card + 1 stick of ram first, to make sure no other things cause the motherboard to stop booting.
If the cpu has no integrated graphics, the video connectors on the motherboard IO shield won't work. You need to connect the display to the dedicated video card.
