Hey guys, I need help deciding on what laptop I should buy. I'm looking at this one right now. I have student discount that gets me it for about 945. What are some other good gaming laptops under 1000?
Thanks in advance!
https://store.hp.com/us/en/pdp/omen-laptop-15-ek0019nr?pStoreID=hp_education
https://linustechtips.com/topic/1293630-omen-laptop/
12 minutes ago, Idk wut im doin said:
At exactly $1000 it's not the cheapest I've seen this laptop, and I would still recommend spending another $100 to upgrade the ram yourself.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1293630-omen-laptop/#findComment-14390223
I have another laptop that I'm planning on switching the ram out with. I also have a 500gb m.2 that im adding in there.
https://linustechtips.com/topic/1293630-omen-laptop/#findComment-14390230
Even less of a reason to get this laptop then, as you're paying $50-150 more than what I would consider the cheapest option if you were to provide your own storage and ram.
https://linustechtips.com/topic/1293630-omen-laptop/#findComment-14390236
