A few issues after upgrading mtb
Solved by TheLawyerMan,
Well, I would reset the bios, you should be able to find out how in either the manual or after a bit of google searching.
7 minutes ago, Andrewsz12 said:“Checking media presence...
Media present...
Start PXE over IPv4...”
I believe this means that the system is checking for a network boot drive. To fix this, all you need to do is fiddle with the boot order in the BIOS.
