I feel like I have a weird need and I don't really know where to look or really even how to convey what I am looking for. Generally, I am looking for a "proxy" laptop or similar device that isnt a tablet. Something I can use to remote desktop my PC, mostly on a home network, so I can have a mobile gaming solution. Something where I can sit on the couch with my fiance while she watches TV and I play games without having to sit at my desk, which is in another room.
I don't really want to give up my Desktop PC since I have a decent PC build:
  • i7-8700K
  • RTX 2060 Super
  • 16GB 3200mhz
  • 1TB NVMe SSD
Which if I was looking to get a Razerblade 15, would almost identical at the base model, with the exception of the 3060 coming out soon. I like my desktop because I occasionally use it for VR. I really wish the NexDock had a way of connecting remotely since I like the design and appeal of that device.
Should I just part out my computer to put the money toward a Razerblade or is there a comparable option?
Any guidance of any kind would be appreciated.
https://linustechtips.com/topic/1293437-need-guidance-with-remote-desktop-solution/
  • i7-8700K
  • RTX 2060 Super
  • 16GB 3200mhz
  • 1TB NVMe SSD
so you want to connect your PC and share its screen to laptop? did I undestand it right?
5 minutes ago, mistermoonlite said:
That is correct. Using my PC as my own version of GeForce Now to a laptop
idk about nvidia, but amd drivers can actually mirror your pc screen to phone. So it should be also possible with nvidia. Nvidia is better, right? :D wait a moment, ill find something. EDIT: seriously nvidia? why does rtx2060 drivers look exactly the same as my old GT630 drivers?
Edited by CreepySK
  • i7-8700K
  • RTX 2060 Super
  • 16GB 3200mhz
  • 1TB NVMe SSD
There are many network based remote access software but all introduce delay that will make you lag in games and your control would suffer.
  • i7-8700K
  • RTX 2060 Super
  • 16GB 3200mhz
  • 1TB NVMe SSD
I would say run a long HDMI to the TV and use wireless controllers but you want to be able to watch at the same time. So not possible you have to "sacrifice" something
