USB c to 3.5mm + charging compatible with s10+?
Solved by Carbonado,
2 minutes ago, MysticDragon said:Title says all really, I broke off a headphone jack in my phone and I have tried a lot of things to get it out (nothing has worked).
So I am looking at usb c to 3.5mm + another usb c connection for charging to bypass the issue, will this work for the s10+?
yes, it will work for the s10+ and there are many such extensions out there like:
