unstable Cpu temps
Go to solution Solved by anonymous2500,
52 minutes ago, Brolf said:
So, i was gaming and had realy bad fps drops out of nowhere sometimes i was wondering what it was checkt my temps and noticed that my cpu was 82 degress told. Was talking to My friends and they said i shut go and get a new cooler. Bought a new cooler put that on (never done it before) but obv checkt alot of vids on how to, anyway after i put on my new cooler my temps are even worse and pretty unstable while idling they are going rapidly up between 45-78 degrees and while gaming it was at some point 89 degrees and also shooting up and down quiet alot. so i was wondering if i did something wrong with the installation or somehting else might be broken maybe the temprature censor ?
PC specs :
CPU : Intel I7 7700K
Cooler : coolermaster masterliquid lite 240
GPU : Nividia Geforce RTX 3070 Gigaybyte
Ram : Corsair 32 GB DDR4-3200
Motherboard : Asus PRIME Z270-P
PSU : 850 Watt
Windows 10 64 bit
Is that graph at the bottom when the CPU is under load? if so your absolutely fine and that was probably a spike, if not make sure the screws aren't lose, the plastic film on the cooler is off, the CPU was cleaned of the previous thermal, and you reapplied thermal paste.
PC specs :
PSU : 850 Watt
Windows 10 64 bit
https://linustechtips.com/topic/1293181-unstable-cpu-temps/
This is pretty normal. The temperature sensor is part of the CPU, and does not break like this. If you want better temps, then set a more aggressive fan curve.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1293181-unstable-cpu-temps/#findComment-14386723
isn't like 78 degrees way to hot for a cpu for just idling and 90 degrees for gaming
https://linustechtips.com/topic/1293181-unstable-cpu-temps/#findComment-14386729
That 78°C was a spike, presumably windows doing something in the background. Your actual idle temps are ~ 47°C which is fine. The TIM is particularly bad in this chips, which leads to difficulty in getting low temps. 90°C is perfectly fine for stock operation.
https://linustechtips.com/topic/1293181-unstable-cpu-temps/#findComment-14386736
PC specs :
PSU : 850 Watt
Windows 10 64 bit
https://linustechtips.com/topic/1293181-unstable-cpu-temps/#findComment-14386810
