Budget (including currency): about $3000 USD
Country: USA
Games, programs or workloads that it will be used for: Livestream for venue
Other details:  Currently using a friend's old mining pc (duo core, a few 2-4 GB video cards). CPU has been our biggest bottleneck for our streaming software. Using OBS right now with Restream. I'm not too sure how the camera routing works (that's someone else's job, I mix sound). We're using a camlink dongle right now to take in footage and have some hdmi's coming off of separate gpu's to run: 1 projector, 2 monitor tv's, and running the computer's monitor off the motherboard.
Here's my current PCpartpicker list:
I'm new to building, so some of this may be rhetorical as I read up more.
My biggest questions are:
 - how do i know if the parts will fit in the case together?
 - Is it worth waiting for new hardware availability? (Ryzen 5000 series &/or Nvidia 3000 series)   ----- We're trying to futureproof our build
 - The computer will be in the same room I mix sound. Should I worry about how loud the PC will be? and does that affect what parts I pick?
https://linustechtips.com/topic/1292480-first-build-will-it-work/
Country: USA
Replace the 1000W power supply with a 750W power supply. You really don't need 1000W, even with an RTX 3090, and it's just paying more. It's a good build for the other parts. My only other advice would the the AF120 fans in the 4000D. While they will work, the newer and better ML120 fans will provide better airflow behind a panel and dust filter than those AF fans, while creating less noise.
Country: USA
Def wait. That 5700XT is literally almost 2.5x msrp.
geometry is hard
b550 > x570
Country: USA
The CPU is not good for the price. Ryzen 7 5800x is better.
No the 5950x is really good for the type of work the OP is doing i.e. Sound Mixing. It has double the cores than a 5800x
18 minutes ago, Downkey said:
This is a great build overall but I suggest a D15 instead of a liquid cooler.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
You said you have budget of $3000.so i suggest you to take following product.
PCPartPicker Part List: https://pcpartpicker.com/list/tJGpF8
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($588.00 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($33.99 @ Amazon)
Motherboard: Asus TUF X470-PLUS GAMING ATX AM4 Motherboard  ($386.00 @ Amazon)
Memory: Team T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($129.99 @ Newegg)
Storage: Crucial P2 500 GB M.2-2280 NVME Solid State Drive  ($52.99 @ Newegg)
Storage: Western Digital SN750 1 TB M.2-2280 NVME Solid State Drive  ($129.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: Asus GeForce RTX 3070 8 GB KO Gaming OC Video Card  ($949.99 @ Amazon)
Case: NZXT H510i ATX Mid Tower Case  ($85.99 @ Best Buy)
Power Supply: Cooler Master MasterWatt 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($86.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($108.78 @ Other World Computing)
Monitor: Acer VG270U Pbmiipx 27.0" 2560x1440 144 Hz Monitor  ($359.99 @ Newegg)
Total: $2967.69
Generated by PCPartPicker 2021-01-11 08:18 EST-0500
Total: $2967.69
-5800x for 3k?
-$33 cooler in a 3k build ;-;
-$400 X470 board for a 5800x??
-3070 in a 3k build?
-Bad PSU
-First SSD has no DRAM CACHE
-Bad case
-Why buy W10 or $100?
-Unless i'm wrong he didn't need a monitor?
geometry is hard
b550 > x570
Thanks everyone for the input! It helps a lot.
14 hours ago, Downkey said:
I like this build. How much trouble is it to install/maintain a watercooling loop? In what cases is it worthwhile?
Side note: we're considering overpaying for a graphics card just to have our final build sooner, but I'm keeping an eye on my local BestBuy to hopefully get a video card and CPU at MSRP.
I just don't like AIOs too many point of failure(pump, leaks, etc.). If you are going with an AIO the main reason would be aesthetics since the D15 matches or out performs most water coolers.
Desktop :
Laptop :
15 hours ago, Downkey said:
-5800x for 3k?
-Bad PSU
-Bad case
Yep, this person knows what there talking about, ignore the other one,
