I got a new 200r and I managed to find the power switch pins, but since Dell does not have a MOBO manual I can't find the pins for my LEDs. I know I should upgrade my MOBO but I spent like $400 in the last 6 months on my computer. So my question is where should I plug the LEDs in? And does any one know a good usb 3.0 to usb 2.0 internal adapter?
Prepare for battle in BATTLEFIELD 4! All New Dog tags JUST LIKE THIS:
https://linustechtips.com/topic/129242-dell-mobo-problems/
To to the Dell website and click on support at the top and then enter your serial number, the doc's are there... B)
Where could one find a serial nuiimber
https://linustechtips.com/topic/129242-dell-mobo-problems/#findComment-1720163
just write down any numbers that are printed on the mobo
Just to give you an idea of what to look for.. :-)
NO! That is the Dell part number.
All Dell's have a serial number on the back of the case (Desktops) or bottom (Laptops), it should contain Letters (in caps) and numbers. Some newer desktops have a black sticker with white writing on the top of the case. If you still have the default OS installed there's a Dell app that will list it. You can also go into BIOS to view it.
Desktop:
Laptop:
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/129242-dell-mobo-problems/#findComment-1720404
