Advice on what base Operating Systems to get for multi-platform deployment
Solved by brob,
Hypervisors manage virtual machines. They host virtual machines that run o/s. A type 1 hypervisor runs on the raw hardware allocating and managing resources for the virtual machines being hosted. A type 2 hypervisor runs in a host o/s and manages virtual machines.
One possible scenario is that the machine boots a hypervisor which then runs a VM that boots Ubuntu to run the vision module and another VM that boots windows 10.
