help with pc build and ram
Solved by boggy77,
2 minutes ago, Tanplayz said:what are the advantages of x570 over b550?
Some professionals may need even more power and extensibility than what the B550 platform can offer. For such professionals, MSI’s X570 motherboards are the ideal choice. If any of the following apply to you, the X570 platform is a better choice:
You use more than 4 USB 3.1 devices
You use more than 6 SATA devices
You use more than 3 Gen 4 M.2 SSDs
3 minutes ago, Tanplayz said:and should i go for 16cl because i dont need to render long videos?
it's not about the length, but about resolution. if the video is 4k or more, you need 32gb.
the difference between c16 and c18 is small. far more important is having 4 ranks, 2 ranks per channel, which you won't have with 2x8 gb, only with 4x8gb or 2x16gb.
