Hello,
So I recently did a complete PC overhaul, yet have yet to change my CPU Cooler. Right now I'm looking at two options;
The first option is a Coolermaster MasterLiquid ML120 v2. With this, I'd be able to have a 200mm Noctua fan mounted on top as I have a HAF XB.
My other option is a Noctua DH-15.
Price is not going to be an issue for me.
Which would leave me with better temps?
https://linustechtips.com/topic/1290573-cpu-cooling-solution/
1 minute ago, JoeROFLCOPTER said:
Hello,
Honestly I think it would be the air cooler, and in the long run, it will probably last longer and give you less problems. What kind of workload and what CPU are you using though?
https://linustechtips.com/topic/1290573-cpu-cooling-solution/#findComment-14367983
Really a gaming rig. It'll be running AAA titles quite a bit.
i7-9700k
Gigabyte 3070 Gaming OC
MSI z390 MPG Gaming Plus
32 GB Corsair LPX 3200 MHz
PowerSpec 650W 80+ Bronze
3 Stock Case fans.
https://linustechtips.com/topic/1290573-cpu-cooling-solution/#findComment-14368005
41 minutes ago, yaboistar said:
DH-15
34 minutes ago, Hay_bale said:
Definitly the noctua
33 minutes ago, Caroline said:
Definitely go for the D15
What if I were to get the ML240 for the same price as the Noctua.
https://linustechtips.com/topic/1290573-cpu-cooling-solution/#findComment-14368106
