4 minutes ago, Bheesham said:
I bought ant esports fp550 watt power supply ... The fan is not working and touching the power supply gives quite some shock... It is not powering the mobo ... It is brand new ...
It comes with a warranty right? Return the dam thing, or demand a refund!
geometry is hard
b550 > x570
https://linustechtips.com/topic/1290511-power-supply/#findComment-14367411
And how can i test a power supply without installing on a mobo ... I am scared because i bought a new mobo and the same incident happen again ... It might be fried next time
https://linustechtips.com/topic/1290511-power-supply/#findComment-14367433
If the housing is shocking you, it is defective and you should unplug from the wall and let it sit and let the power drain out without touching.
I have no idea what brand that PSU is, but there is a sticky in this subforum with reputable power supplies by brand and wattage; id refer to that before buying a new one.
https://linustechtips.com/topic/1290511-power-supply/#findComment-14367434
-Merged-
Please don't double post
https://linustechtips.com/topic/1290511-power-supply/#findComment-14367456
