Hello, today I will build my first ever pc, call me EXCITED!!
I saw some stuff how its bad to build on carpet? but most my house is literally carpet and I dont really want to build it in the bathroom
I saw how I can just build it without socks on and it should be fine?
I am just scared to not mess anything up
Thank you
https://linustechtips.com/topic/1290411-need-help-with-build/
If you can wait a little while an ESD wristband that plugs into the wall would be a worthy investment of about 6-12$. I have seen plugging in the power supply and touching it to ground yourself. The wristband is a better option tho.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1290411-need-help-with-build/#findComment-14366442
So If i did it on parquet would that still be an issue?
I also some some stuff about taking socks off and touching walls or pc case before making contact with a pc part
https://linustechtips.com/topic/1290411-need-help-with-build/#findComment-14366485
