So i decided to build my 1st gaming pc, I would love to hear what parts you would recomend me to use in build of this price range. I am also litle concerned about how powerfull PSU i should use, because i am not sure is the 600W one enough for running this build?
http://pcpartpicker.com/p/3cdgB
CPU: intel i5 4670k
Motherboard: ASRock Z87 Pro4
RAM: Kingston HyperX 8GB 1600MHz DDR3 (single stick)
Storage: Samsung 840 EVO 250GB SSD and Western digital green 1tb HDD
GPU: Gigabyte GeForce GTX 770 2gb
Case: Fractal Design Define R4
PSU: Corsair CX 600M 600W 80PLUS bronze
I will also have blu-ray drive and my OS will be windows 7
Would love to hear dem part Recommendations, Best regards Jim :D
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/
whats your budget and location? quote me if you want me to get back to you
Specs
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1716497
600W is heaps but that isn't a great choice of power supply. Not sure why you've chosen to get a single stick of RAM really, doubt you will ever need 4 sticks of 8 on that system, start with 2x4GB unless you have money to throw around and want 2x8GB - but cooling and better PSU should come first.
Current rig: i5 4670K | GTX 670 | Asus Z87I-Pro | Silverstone Strider Plus 600W | Custom mITX case | Seagate Barracuda 3TB | Samsung 840 120GB | G430 | CM Storm Quickfire Pro - MX Red | LG 21.5"
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1716642
The psu is more than enough.
What's the system being used for?
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1718133
system is mainly used for gaming and regular computer, use single stick of 8gb ram is cheaper here in finland than 2 sticks of 4gb  ^_^, for peripherals I have sennheiser 598HD, Fiio e10 usb dac, Razer naga, Blue microphones yeti, some random microsoft gaming keyboard, printer and speakers and webcam that I rarely use. Would you recomend some other PSU then? I am not going to buy second GPU or anything what would use alot more power. My budget is hard to tell because some parts cost alot more and some alot less in finland than in US but it's max 1300usd that system up there was 1100usd and i would not like to use alot more...
well i might get Cooler Master Hyper TX3 Evo CPU cooler.
I am also trying to make the system quiet like you might see from the case i picked.
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1720070
What shops are you using? What's your actual budget?
Don't waste time converting currencies because parts and prices very from region to region and sales vary even more so.
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1720458
i suggest, a much cheaper case, like the n400 or n600 from cooler master, maybe even the carbide 200r.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1720463
my budget is max 1300usd
So you're shopping from US shops and shipping to Finland?
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1720951
I am doing both shopping from us shops the cheapest items that I can still get cheaper whit extra taxes and shipping and getting the parts that are cheaper to buy from finland from local pc stores.
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1720966
Won't fees an such make shopping from the US just as expensive as shopping form Finland anyway?
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1721007
Yep they do but some parts are so extremely cheap out there that it's still cheaper to buy them there with the shipping cost and the taxes.
Parts that i am going to buy from US are HDD SSD and mayby RAM.
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1721201
Well, you're fine with just about any 8GB kit of ram, any decent 120/128GB ssd, and a seagate barracuda with capacity of your choice.
There's not much part choosing to be made for these.
So.. shall we head onto where you'll be shopping for the bulk of your parts?
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1721222
well I am going to buy the most of the parts from online pc store called jimms pc here is link but the site is only in finnish
http://www.jimms.fi/
SSD,HDD and RAM I am going to order from amazon US
Thanks guys for your help and recomendations I consider of getting some cheaper case and diferent PSU and mayby smaller SSD!
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1721605
What's your budget for the rest of the parts?
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1722711
I would use 351$ for ssd hhd and ram from amazon (is still cheaper than from finland) and for the rest of the parts I will order from finland, I would have around 700€ (in dollars 950$) for them.
PS. Sorry my english is not the best in the world :unsure:
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1727031
How's this look?
https://linustechtips.com/topic/129010-my-1st-pc-build-plan/#findComment-1727736
