Applications starting delay
Solved by Un1verses,
3 minutes ago, Radium_Angel said:How is your packet loss on your internet connection?
Raw speed is one thing, but if you are dropping packets left right and center, you're gonna have delays.
This is a quick and dirty way to test, though there are better ways to test this stuff
This: https://www.pingplotter.com/ is much better (free trial avail)
I downloaded pingplotter, although I have no idea what to do with it or what to look for. I also did the test, here's the results. https://gyazo.com/97b678d64ff7737f134489bff6f0c4f9
