Hi guys! So, I'm pretty new to this whole forums thing and I badly need an advice. What happened was, my previous PSU just failed. So, I brought a new one. Now, with my current PSU which is a YGT 700w, which is generic, I'm having trouble using my GPU as when I plug my VGA cable to it, the screen says that no signal is detected. Now, this have me plugging the VGA directly to the Mobo (Mother Board), which is I do not want to happen, and also one my ram slot or the ram itself seems to be corrupted. I now end up with a 4gb GSKILL Ripjaw RAM, Intel Pentium G4560 CPU and my GTX750Ti 2GB 64Bit GPU. I'm basically thorn between changing the RAM or the Mobo itself. Either way, I will also be upgrading my GPU. This setup cost me at around 15,000 Philippine peso. I need help, I don't know what to change first as I really do have a tight budget right now. Please help.
PS. I'm not really a techie guy so please do elaborate your responses. TIA.
https://linustechtips.com/topic/1289936-need-an-advice/
16 hours ago, LogicalDrm said:
-> Moved to Troubleshooting
This is bit confusing.
Does system boot up at all? Like fans spinning? Do you get image when connecting monitor to mobo?
Well, yeah. It's running, I have images on the monitor when I plug it directly to the mobo. All fans i also working.
https://linustechtips.com/topic/1289936-need-an-advice/#findComment-14366323
Then it's the GPU which is the issue. Does it have 6pin PCIe power connector?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1289936-need-an-advice/#findComment-14366402
1 hour ago, ThatAsianKid said:
Apparently, no. Its just a direct to the mobo type of gpu. It doesnt have a slot for connectors and all that.
Ok, have you tried to re-seat it or tried using another slot? Would it be possible to try with DVI or DP and adapter for VGA?
https://linustechtips.com/topic/1289936-need-an-advice/#findComment-14366948
The gpu has an DVI, VGA and HDMI port. I tried all three and still no signal was detected. That is why im now directly plugged to my mobo. The fan on my gpu does work tho. So i dont know what the heck is the matter with this thing.
https://linustechtips.com/topic/1289936-need-an-advice/#findComment-14367028
Yeah, sadly I don't either. Other than testing all variables first.
It could be damaged at some point, but that's really hard to say for sure.
https://linustechtips.com/topic/1289936-need-an-advice/#findComment-14367218
Well, im already keen on upgrading my gpu since it gives me a lot of headache. Lol. So, should i first upgrade my ram or just replace my mobo. I mean, since im running with a 4gb ram rn, its bottlenecking.
https://linustechtips.com/topic/1289936-need-an-advice/#findComment-14369221
