 I've worked on my first PC for a straight 5months of collecting parts and putting all together according to the book. But I dont know how the headers of an InWin925 go on a asus rog strix z490-e gaming go on it 😧 ! Can anyone provide a picture of it or a guide I'm a slow learner but I've tried to follow guides and just get lost here.
https://linustechtips.com/topic/1289428-need-help/
15 minutes ago, FrostMyFlakes said:
Thanks I'll move it up. Ive tried to read the manuals but I just dont get it and the InWin manual is a joke
If you're talking about the front panel, referring to motherboard's manual will help much better. If you're talking about some other connectors, pls specify, I cannot comprehend😶😅
https://linustechtips.com/topic/1289428-need-help/#findComment-14359266
Next time read the motherboard manual...
It's all there.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1289428-need-help/#findComment-14362732
1 hour ago, FrostMyFlakes said:
Thank you guys for all the help. Yeah it was the front panel headers. I can hopefully get to work on this. I just didnt understand it at all. So many videos just skip over it.
Can you post a photo of front panel cables from your case? Make descriptions on cables connectors visible on the photo.
https://linustechtips.com/topic/1289428-need-help/#findComment-14362771
