...dare I say new.
I got an old Gigabyte GA-78LMT-USB3 Rev. 6.0 from a friend who works at a tech shop. (it was in the recycle pile, so it's definitely not new or in good condition)
When I go to power on the machine, I get this weird coil whine that sounds like it's coming from the CPU fan. I also get these blue artifacts in bios (this is only without an external Gpu installed) and it won't detect peripherals or boot into Windows.
When I do have a Gpu installed, I can get into Windows but it runs in a stretched resolution and fails to read the data on my SSD (so it uses a temporary account)
Is this an issue with the Psu? Or is this caused by something wrong with the board? Specs below:
- Amd Phenom II x4 955 CPU
- Gigabyte GA-78LMT-USB3 6.0 mobo
- Sapphire Vaporx HD 4870 1GB GPU
- 128GB HP SSD
- 16 GB RAM
- 1 TB HDD
- Thermaltake smart 500W PSU
https://linustechtips.com/topic/1288627-new-motherboard-causing-problems/
Might be going out on a limb, but...
I'm gonna start by assuming the motherboard is most likely the issue.
Does using a Linux USB have any difference?
Primary PC:
PSU tier list
How many watts do I need?
I found out the issue was the Ram, oddly enough. Using one stick seemed to fix the problem and it boots to windows 10 correctly. Thanks for responding though!
