hmm. why use old fans, the corsair  QL 120 fans are drawing 0.30A, else the EK Vardar EVO 120ER is drawing 0.18a.
the EK serve better radiator fans and pushes good static pressure airflow compared to the QL120.
you might just use your QL120 as case fans. Just a suggestion.
https://linustechtips.com/topic/1287894-cooling/#findComment-14350936
