  • 2 weeks later...
LGA 1200 and 115x sockets use the same cooler mounts. The only reason that comes to mind for a 115x water block not fitting on 1200 would be if it was designed for a specific motherboard or the motherboard being used is not conforming to the socket keep-out-zone which is a specification followed to ensure cooler clearance.
https://linustechtips.com/topic/1287875-cooler-compatibility/#findComment-14387011
