Hello,
I was recently playing DOOM 2 and I went to look at my temps out of curiosity and saw I was running at 87 Celsius! Naturally this caused me to stop playing as I wanted to observe the idle temps. The lowest I've seen my CPU hit while nothing is running is 51 degrees, which seems very high. I ran a stress test and the maximum temperature that was achieved was 90 and it never moved above that.
After all this I decided to reapply the thermal paste of the CPU to see if that would help but alas the results are still the same. The CPU is question is a ryzen 5 3600 bought relatively recently and I am using the stock cooler. I have a Phanteks case which has some of the best airflow on the market right now and I've heard that the Wraith is a really good cooler. I have not overclocked so these temperatures are really concerning. I was wondering if anyone had any ideas as to why they would be so high.
Thanks,
Aktarius
https://linustechtips.com/topic/1287833-cpu-temps-running-hot/
3 minutes ago, Aktarius said:
stock cooler
You answered your own question.
The stock cooler was never made for high intensity work. Get a better cooler.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1287833-cpu-temps-running-hot/#findComment-14347179
You're using the Wraith Stealth. Those aren't that great, and I didn't even realize that the 3600 shipped with the Stealth. You'll want to get a better cooler.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/1287833-cpu-temps-running-hot/#findComment-14347229
