I just finished building my pc but when booting it up i have a issue, the issue is that now it says automatic repair couldn't repaire your device and i tried troubleshooting and doing everything i see on youtube but i have no fix yet. Do you guys have any recomendations plz.
https://linustechtips.com/topic/1287246-booting-probleme/
How did you install windows?
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343004
2 minutes ago, Hazmaticpixel said:
im pretty sure i put it on the ssd using a usb
How do you not know..?
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343020
im pretty sure i put it on the ssd and i used a usb and do you know if there is any way to hard restet a ssd so i could start from scratch
Is this SSD from a different system?
Please ensure you quote when you reply so I get notified
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343032
i had another pc like a dell optiplex that i upgraded now i got a new cpu and motherboard so i used the other ssd from my old computer that had windows and worked fine
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343040
Reinstall windows.
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343053
1 minute ago, Hazmaticpixel said:
i dont know how because i dont have any pther options then to trouble shoot
What do you mean?
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343068
You'll use a USB to reinstall windows, not the default troubleshooter.
Create one if you dont have one using the tool
https://www.microsoft.com/en-ca/software-download/windows10
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343086
thank you but how will i reinstall windows its just my brother did it for me like do i just insall it like i would or do i need to delete windows first
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343110
You use that tool to create a bootable usb drive
You plug it in, boot to it, and follow the prompts
https://linustechtips.com/topic/1287246-booting-probleme/#findComment-14343117
