So i wanna make a good gaming pc since i finally got a good amount of money gathered up and i wanna make sure that everything works together but i dont really trust just my research so some opinions would be great
For a case, im gonna be using the NZXT H710i
For a GPU i am getting an rtx 2070
For a CPU i wanna get the AMD Ryzen 9 3900x
For the mobo, the MSI MAG tomahawk b550
Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 RAM
For a PSU i going to be using the Cooler master MWE 650w 80+gold
and for storage im gonna my old ssds and hard drives.
If anyone has some tips or see any problems with the build please let me know
https://linustechtips.com/topic/1286733-need-help-building-a-pc/
Your gpu will bottleneck your cpu by quite a bit. If you are not in a rush building your pc i would wait until the rtx 3070 and 3060 ti as they will perform significantly better. If you can't wait go for a 2070 super or 2080 or maybe downgrade your cpu.
2 minutes ago, brob said:
Why the Nzxt H710i?
Did you consider the RTX 3070?
What CL on the memory?
Did you consider the 5900X?
How do you plan on cooling the cpu?
For his build the 5900x would probably be overkill and at a higher price.
Why the Nzxt H710i?
I wanna get that case cuz i just like the way it looks and it has an RGB and fan controller
I already have the rtx 2070 so i thought i wouldnt need to buy a new one
I did think about getting the 5900x but then i thought that it could bottleneck my gpu if i got a better one
as for cooling i just thought i would use the stock cooler that comes with the cpu since i dont plan on overclocking
35 minutes ago, johnSPA12 said:
the 5600x is compatible with the tomahawk motherboard right?
Yes. The motherboard supports the USB BIOS Flash  feature that allow bios updates without an installed cpu.
