So I have 3 hard drives, all of them need defragmentation to be done, since they are high capacity drives, it will take a while...my question is - can other drives be accessed for music files pictures videos etc, if one of them is defragmenting? In the past I was leaving pc to defragment hard drive 1 of 3 and was doing nothing with pc at all...main drives (OS) is an ssd
CPU: R9 9950x, CPU Cooler: Arctic Liquid Freezer III 420 + 3 x Noctua NF-A14x25 G2, GPU: Gigabyte RX 6900XT Aorus Master, Motherboard: ASUS Chrosshair X670E Hero, RAM: Corsair Vengeance 64GB DDR5 6000 CL30, Soundcard: Asus Xonar STX, Storage: Samsung 990 Pro 4TB, Samsung 970 Evo 1TB, Samsung 870 Evo 4TB, 3 x WD Ultrastar 20TB, 2 x WD Ultrastar 26TB, PSU: Seasonic Prime 850w 80+ Titanium, Case Fans: 4 x Noctua NF-A14, Case: Corsair 7000D Airflow, OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/1286233-hard-drive-usage-during-defragmentation/
With windows 10, you don't need to manually defragment the drive especially the SSD drive.
It will defragment automatically in the background.
I've not touch defragment for like 5 years.
I know about ssd's which get trimmed, but, I've turned that feature off because there was some information floating around the net tha new windows version of 2xxx borks some users pc's if defragment automatically is on
