Budget (including currency): 1500€ (MAX)
Country: Portugal
Games, programs or workloads that it will be used for: The main purpose will be gaming, but I will use it also to watch some movies and office works.
Other details:
My country (like every other I guess) is facing some problems with stocks so the main problem is with the CPU and GPU. Finally it has started to appear in the stores.
Till now I have:
Motherboard: MSI B550 Gaming Edge Wifi
CPU Cooler: Arctic Freezer 34 eSports DUO
Power supply: Seasonic Focus Gold 850W.
SSD: Samsung 970 Evo Plus 1TB
HDD: WD Blue 1 TB.
Case: Phanteks P400A Digital Black.
RAM: 16 GB x2 3600mhz. CL16 G skill ripjaws.
Monitor: LG 27GL850-B
I spent around 1000€ with the listed components and I can spend a max of 1500€ with CPU,GPU and also a mechanical Keyboard.
My doubts are:
CPU: Ryzen 5600x, 5800x or 5900x? Prices in my country for each are around, 315€, 470€ and 570€.
GPU: 3080 or 6800 XT and what is the most recommended custom card among those.
Keyboard: I wanted to spend the max of 150€ for the keyboard and was looking for some model good for both gaming and typing with numpad but I don't have much references.
Best regards.
https://linustechtips.com/topic/1285957-help-with-cpu-and-gpu/
The 5600x will be good for you.
For GPU, if you only care about FPS the 6800XT is a good card.
If you stream or do any content creation, the 3080 will be better.
Potato Revamp
CPU: AMD 5900x || GPU: nVidia RTX 3080 || RAM: 32gb Trident Z Neo CL16 || Case: Fractal Torrent Compact || CPU Cooler: Scythe Fuma 2 || PSU: Corsair RM850 Gold || Storage: ADATA SX8200 Pro (1TB), 2x Samsung Evo 870 (2TB)
https://linustechtips.com/topic/1285957-help-with-cpu-and-gpu/#findComment-14334504
Thanks for your answer.
Since the prices of both here are similar (the 6800 XT released much higher than the MSRP) I think that it might be better go for the 3080 (in case I need something else apart from the FPS). Is there any model that is more suggested (I looked in particular for TUF and SUPRIM).
https://linustechtips.com/topic/1285957-help-with-cpu-and-gpu/#findComment-14334525
If I recall, most are pretty good.
Asus, EVGA, Gigabyte and MSI are putting out pretty good products.
TUF is a good choice.
Potato Revamp
https://linustechtips.com/topic/1285957-help-with-cpu-and-gpu/#findComment-14334534
