D3 Error Code, PC freezing Randomly
7 minutes ago, doggywoofster said:Hi, I just build my new computer. I installed windows 10 Pro. Sometimes in windows my screen freezes and I have to push the power button to turn it off. After the screen freezing when i go to turn it on it says windows is unable to boot. But then i hit restart and it boots. Sometimes when I run ryzen master I get a d3 error code and my system restarts. I do not get a blue screen. I have not updated my BIOS because it says im already on the latest bios. I have only done one overclock, on the ram. Im running the ram at 3600mhz at 1.39v. My CPU is at about 67c at 50% usage. (I never go over 50% usage).How can I fix these issues of the d3 error and the screen freezing?
My System
CPU: AMD Threadripper 1900x
CPU Cooler: Noctua NH-U9 TR4-SP3
Motherboard: Gigabyte X399 Aorus Pro (Rev 1.0)
Memory: G.Skill Trident Z RGB 3600mhz 16-19-19-39 (4 sticks, 64gb total)
Storage: Samsung 970 Evo 500gb (I have 2 in this system, total of 1TB)
GPU: MSI Ventus 3x OC 3070 (Studio Driver)
PSU: Corsair RM850X
Case: Lian Li pc-o11 Dynamic
Fans: I have 6 fans. 3 Intakes and 3 outtakes.
Software: Windows 10 Pro
First time building a system and I am a little nervous about this so any help is much appreciated.
1st gen Ryzen (especially Threadripper) has a hard time running anything faster than 3200MHz. Try disabling or running a lower memory speed and just tightening your timings, and see if that fixes it
