  • 2 weeks later...
This will work also.  You just need to make sure your motherboard has 2 USB 2.0 headers available.  You'll connect both the Commander Core and Lighting Node Core to both ports.  The fan speed will need to be controlled by one of the PWM headers on the motherboard.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
https://linustechtips.com/topic/1285841-new-build-help/#findComment-14360514
