GPU &' CPU Cooling Questions &' Help needed!!
Hey, i wanted to ask if those Temperatures are good or bad, and if they are bad what could i change?
Information to the Computer, week old, build myself ofc, using 2 front fans (meshify s2 case) 1 back &' 3 top (CPU Cooler) Arctic Liquid Freezer II (360)
I also didnt touch my CPU at all, and im not sure if my cpu isnt to hot and if it would make a difference when i adjust the volt or something, please help :D
If more information is needed i will provide it!!
https://linustechtips.com/topic/1285757-gpu-cpu-cooling-questions-help-needed/
GPU temperatures are fine. What's your CPU Utilisation? I might invest in a better cooler if it isn't high.
Edit: just saw what you just posted, those temperatures are absolutely fine
Edited by BeauTheBeau
Those are amazing temps. You have nothing to worry about.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
1 hour ago, lolinie said:
really? i feel like 80 is alot for my CPU :o?! and if can i maybe lower it a little?
80 for an i9 10900k is not high at all. Those are some damn hot chips. Even the nhd15 cant keep them below 70 degrees when they are boosting normally.
Desktop :
Laptop :
