So I’ve recently purchased a phanteks neon rgb strip (http://www.phanteks.com/Neon.html), however my motherboard doesn’t have an rgb header (Asus z370p). Since these are aura sync compatible is their any sort of rgb controller I can get which allows me to use the aura sync software.
https://linustechtips.com/topic/1285302-which-rgb-hub/
3 minutes ago, OrbitXT said:
So would that mean I have to get a new motherboard with an rgb header if I wanted to use any software with it
Like this controller you must have an USB port on your MOBO to work.
BUT IF YOU HAVE A USB PORT THEN THIS CONTROLLER WILL DO.
RGB LED Controller | Cooler Master
https://linustechtips.com/topic/1285302-which-rgb-hub/#findComment-14330812
Is there other brands that do a product like this or are they the only ones
https://linustechtips.com/topic/1285302-which-rgb-hub/#findComment-14331050
