can someone help me i buy a new gpu my old was gtx 1050 2gb and now i have rtx3060ti
pc:rtx 3060ti
ryzen 7 2700x asus b450-f
16gb dual channel bought 3000mhz
650watt bequit
my problem is i have on low settings same fps and as on high settings my gpu usage is on low settings 10-25% and on high i get 70-90%
https://linustechtips.com/topic/1285267-low-gpu-usage/
How many fps and in what game?
That means you're limited by your CPU, not your GPU.
F@H
GPD Win 2
https://linustechtips.com/topic/1285267-low-gpu-usage/#findComment-14330522
8 minutes ago, Chris Fortune said:
What game is this?  I had an R7 2700 and was rarely CPU locked with a 2070 even on the lowest of settings, admittedly the 3060Ti is a much better part but I am suprised at the numbers you quoted.
i tested in fortnite and in watch dogs 2 in watch dogs on lowest settings 50% on highest it get to 95%
https://linustechtips.com/topic/1285267-low-gpu-usage/#findComment-14330551
Not surprised at the Watchdogs numbers to be honest, did you turn on nay RT functions or DLSS when you upped the settings?
https://linustechtips.com/topic/1285267-low-gpu-usage/#findComment-14330556
no
but i dont care of watch dogs i buy new graphics card because i play fortnite competetive
https://linustechtips.com/topic/1285267-low-gpu-usage/#findComment-14330570
10 hours ago, classix said:
fortnite 180-200 and on low 210-240
So pretty definitely CPU bottleneck. If you had said 100 then there would have been another problem but not at 200.
So up the graphics settings a bit to make use of your GPU and live with it.
F@H
GPD Win 2
https://linustechtips.com/topic/1285267-low-gpu-usage/#findComment-14331657
  • 2 weeks later...
Kilrah is right, you re not alone in this Chris, i am with rtx2060 & i5 9300, my gpu usage is low in fortnite and i don t really feel comfortable in playing with high graph settings since i am on laptop, life expectancy woon t be going that far at high temeperatures.
https://linustechtips.com/topic/1285267-low-gpu-usage/#findComment-14360911
