i have this keyboard that ive been using for 6 months, the other day i decided to test some other "gaming" keyboard that my grandma had. Turns out some strange config thing about that one changed some of my keys and i dont know what it is.
The keys it changed are as follow: the D key seems to have been swapped by left ctrl and viceversa (when in browser pressing d brings up my markers), the fn key opens windows mail for some reason. Pressing the "¿" key types a "k¿" (and every time i press K the same happens) My f9 key just types a P.
As i said i dont know what i did to activate this "mode" but i suspect it has to do with my keyboard's multymedia keys that are built in to the fn button. (it is a spanish qwerty if that helps)
sorry for the bad english.
https://linustechtips.com/topic/1284376-weird-key-issues/
2 hours ago, Ciarhda said:
its a CX-617EL (basically cheap thing i found here) i dont k¿now if that helps
I wasn't able to find an owners manual for it, if you have one or could find one, look through it to see if there is instructions on how to change modes.
https://linustechtips.com/topic/1284376-weird-key-issues/#findComment-14324732
