5 minutes ago, biigcan said:
just replaced my gpu and cpu but whenever i turn my pc on the first thing it says is “DP no signal” and then a black screen. The dp cable connection seems fine and the gpu is turning on but I can’t figure out what could be causing the problem.
Does your motherboard have onboard video? Test that if it does.
Sounds like you could have a DOA GPU, but you need to test a few things first.
Can you give us specs? (CPU, GPU, motherboard, PSU, RAM)
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1283913-dp-cable-no-signal/#findComment-14321286
Aorus b450 AM4, rx 5600 xt, Ryzen 5 3600 xt, 16gb Gskill TridentZ
https://linustechtips.com/topic/1283913-dp-cable-no-signal/#findComment-14321308
Ok, so no iGPU to test with...
Do you have another cpu you can test with? Possibly a 2000 or 1000 series? It could be an out of date BIOS that needs an update for 3000 series chips.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/1283913-dp-cable-no-signal/#findComment-14321504
2 minutes ago, biigcan said:
I have a ryzen 5 1600
Try swapping that out and see if that works.If it does, you need a bios update before the B450 board will work with it.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/1283913-dp-cable-no-signal/#findComment-14321527
Gonna be honest I don’t know how to update the bios... and am i gonna need to reapply thermal paste or should i even bother with using a cooler on the old cpu to update the bios.
https://linustechtips.com/topic/1283913-dp-cable-no-signal/#findComment-14321555
I'll post a video at the end of this post for updating the BIOS. I would just reuse the thermal paste on the cooler for the old CPU, just to update the bios.
After updating the bios, I would reapply thermal paste for the new CPU.
Here's the best tutorial I can find the gigabyte Aorus b450 family of boards.
Let me know if you have any more questions!!
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/1283913-dp-cable-no-signal/#findComment-14321687
