Hello since this morning my Laptop has had a problem which when i turn it on  and try to game for a like 5-10 minutes it freezes and i can't do anything and I have to unplug it (the battery iis removed a long while ago due to it being unable to hold a charge and shuts off immidiately after being unpluged) and after I turn  it on again it freezes again after 5-10 minutes. Is there any way to solve this problem since i can't afford to buy a new one or even take it to a shop to fix it.
Thanks in advance
https://linustechtips.com/topic/1283518-i-need-help/
did you check thermals? CPU usage? Anything that might explain what causes the crashes?
any details you can share would be helpful.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1283518-i-need-help/#findComment-14318680
