Hey so I have been doing my research and looking up parts so i could build my first pc. i wanted to see if my build was good and if there was anything you would do differently to improve. I also check that all of it will work together but i would like to see if someone could help me confirm that. My build is going to be in a Evolv X case with a MSi B550-A pro motherboard. I plan on getting a Ryzen 5800x CPU with a Nvidia 3080 founders edition. I am going to use my old ram from my current pc which is XPG Z1 ddr4 3000MHz. I will be cooling my pc with a NZXT Kraken x73 RGB 360mm AIO with the radiator on the front panel with the tubes on the top. I will also be getting NZXT triple 120 mm AER RGV 2 starter kit for the top with the RGB controller and 1 AER RGB 2 120mm for the back of the case. I will be using a NZXT C750 power supply to power all of it. This is my build that I have done some weeks researching and putting together to put together my dream desktop. I want to know what you think about it and if it is a solid build an what I could do to improve it if there is a way. I also want to know if the cooling will be enough to have the 5800x overclocked and a good enough power supply to do so.
Thank you all in advanced for responding it means a lot.
https://linustechtips.com/topic/1281196-final-build-thoughts/
its solid and great!
but it would be much better with an 850 w gold power supply
3000 series gpus have sudden spikes in power and you need a powerful enough power supply to handle it with no problem
if you want to overclock
well maybe considering something with better efficiency or even a 1000 watt
but that would be unnecessarily and its just for safety reason and 5800x is powerful enough for gaming
a great power supply wont Traeger his Protective features if its decent enough to handle the spikes
https://linustechtips.com/topic/1281196-final-build-thoughts/#findComment-14302394
750W is enough, but I would recommend at least 800W. Also, you will need MUCH faster RAM. 3600Mhz is the lowest I would go with Ryzen 5000.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1281196-final-build-thoughts/#findComment-14302403
oh I will defiantly get the 800w. using the ram from old pc was to save some money I do plan on upgrading them in the future
https://linustechtips.com/topic/1281196-final-build-thoughts/#findComment-14302518
hey thanks i will for sure get a better power supply
https://linustechtips.com/topic/1281196-final-build-thoughts/#findComment-14302522
