Posted December 14, 2020 Been scratching my head over the past few months i currently am running the following specs: r7 2700x msi b550 mag tomahawk MSI Gtx 1660 super 32gb corsair vengance lpx ddr4 ram When i put my RAM into slots 2 and 4 or 1 and 3 it shows half of my ram being detected in bios. but when it detects the ram in the slot. if i put it in lets say 3 and 4 it detects the 32gb of ram instead of just 16gb. If i go into task manager though it says 16gb allocated but the top right shows 32gb total im a bit confused, is the ram being properly utilized or is there some other problem wrong? Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 can you put them on slots 2 and 4 and check cpuz and what it has to say. I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time. Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300432 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 Author theyre in 2 and 4 right now let me check. and do you mean hwmonitor cpuz or cpuid? Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300440 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 cpuid @Aereth Nvaren I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time. Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300443 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 Author 1 minute ago, SavageNeo said: cpuid @Aereth Nvaren Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300445 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 2 minutes ago, Aereth Nvaren said: ok so it regognises the 32gigs. Can you show the "SPD" tab form all the modules. Also it only runs at 2133mhz plz enable XMP or DOCP form the bios. I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time. Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300449 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 Solution 6 minutes ago, Aereth Nvaren said: CPU-Z properly sees all 32GB. Wait...WHY did you get a B550 motherboard for a Ryzen 2700X ??? B550 boards DO NOT support 1000-series and 2000-series CPUs (they wont work properly with them). It ONLY supports 3000-series and 5000-series CPUs. AMD Ryzen 9000 Rig AMD R7 9800X3D + Alphacool CORE 1 w/ Performance Mount Kit + Thermal Grizzly AM5 Contact Frame Gigabyte X870E Aorus Pro Ice 32GB (16GB X2) G.Skill Trident Z5 Neo RGB DDR5-6400 Sapphire NITRO+ 6800 XT Special Edition + EKwb Full Cover Block Custom Loop w/ 2x 360mm Radiators WD SN850X + WD SN750 + Samsung 980 EVGA P2 850W + Red/White CableMod Cables Lian-Li O11 Dynamic EVO XL AMD Ryzen 5000 Rig AMD R7-5800X Gigabyte B550 Aorus Pro AC 32GB (16GB X 2) Crucial Ballistix RGB DDR4-3600 Gigabyte Vision RTX 3060 Ti OC EKwb D-RGB 360mm AIO Intel 660p NVMe 1TB + Crucial MX500 1TB + WD Black 1TB HDD EVGA P2 850W + White CableMod cables Lian-Li LanCool II Mesh - White Intel i7-8086K / Z390 Rig (Decommissioned Q2' 2025) Intel i7-6800K / X99 Rig (Officially Decommissioned, Dead CPU returned to Intel) Intel i5-4690K / Z97 Rig (Decommissioned) AMD FX-8350 / 990FX Rig (Decommissioned) AMD Phenom II X6 1090T / 890FX Rig (Decommissioned) <> Electrical Engineer , B.Eng <> <> Electronics & Computer Engineering Technologist (Diploma + Advanced Diploma) <> <> Electronics Engineering Technician for the Canadian Department of National Defence <> Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300450 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 also as @-rascal- said b550 board does not officially support 2700x. Lucky that you even booted. I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time. Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300454 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 6 minutes ago, -rascal- said: CPU-Z properly sees all 32GB. Wait...WHY did you get a B550 motherboard for a Ryzen 2700X ??? B550 boards DO NOT support 1000-series and 2000-series CPUs (they wont work properly with them). It ONLY supports 3000-series and 5000-series CPUs. Nice catch. CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300462 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 Author Yeah turns out thats the problem, if you look at cpu-z it just shows ryzen SOC,looks like ill have to upgrade come tax season. i was able to overclock my 2400mhz ram to 3200mhz at least while in single channel, so looks like i lucked out with that at least. I didnt realize they completely cut support for 2nd gen ryzen,usually amd is pretty good about supporting older CPU's, 2nd gen isnt even that old maybe what 2 years at least? Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14300548 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 14, 2020 8 hours ago, Aereth Nvaren said: Yeah turns out thats the problem, if you look at cpu-z it just shows ryzen SOC,looks like ill have to upgrade come tax season. i was able to overclock my 2400mhz ram to 3200mhz at least while in single channel, so looks like i lucked out with that at least. I didnt realize they completely cut support for 2nd gen ryzen,usually amd is pretty good about supporting older CPU's, 2nd gen isnt even that old maybe what 2 years at least? Zen 2 actually came out in summer 2019. The B550 and A520 boards were late to arrive compared to X570. I think they wanted to avoid the similar issue on B550 of "maybe Ryzen 5000-series support with B450 and X470 motherboards." Because of this, if the user updates the BIOS to support Ryzen 5000-series on B450 / X470, they PERMENENTLY lose support for Ryzen 3000-series and older. You got Mr. Bob Dole here...sees a new BIOS update their B450 board, updates it, now the Ryzen 3600 doesn't work now....and they need a new motherboard. Instead of the "maybe" they might have just went completely "No" to Ryzen 2000-series and older, just to be on the safe side. As far as...if the B550 chipset has any major difference compared to X570 that would for some reason make it not work with older Ryzen CPUs...I don't know. AMD Ryzen 9000 Rig AMD R7 9800X3D + Alphacool CORE 1 w/ Performance Mount Kit + Thermal Grizzly AM5 Contact Frame Gigabyte X870E Aorus Pro Ice 32GB (16GB X2) G.Skill Trident Z5 Neo RGB DDR5-6400 Sapphire NITRO+ 6800 XT Special Edition + EKwb Full Cover Block Custom Loop w/ 2x 360mm Radiators WD SN850X + WD SN750 + Samsung 980 EVGA P2 850W + Red/White CableMod Cables Lian-Li O11 Dynamic EVO XL AMD Ryzen 5000 Rig AMD R7-5800X Gigabyte B550 Aorus Pro AC 32GB (16GB X 2) Crucial Ballistix RGB DDR4-3600 Gigabyte Vision RTX 3060 Ti OC EKwb D-RGB 360mm AIO Intel 660p NVMe 1TB + Crucial MX500 1TB + WD Black 1TB HDD EVGA P2 850W + White CableMod cables Lian-Li LanCool II Mesh - White Intel i7-8086K / Z390 Rig (Decommissioned Q2' 2025) Intel i7-6800K / X99 Rig (Officially Decommissioned, Dead CPU returned to Intel) Intel i5-4690K / Z97 Rig (Decommissioned) AMD FX-8350 / 990FX Rig (Decommissioned) AMD Phenom II X6 1090T / 890FX Rig (Decommissioned) <> Electrical Engineer , B.Eng <> <> Electronics & Computer Engineering Technologist (Diploma + Advanced Diploma) <> <> Electronics Engineering Technician for the Canadian Department of National Defence <> Link to comment https://linustechtips.com/topic/1280946-dual-channel-ram-help/#findComment-14302490 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
