Budget (including currency): $600-$800 SGD
Country: SINGAPORE
Games, programs or workloads that it will be used for: GTA IV, GTA V, MAFIA REMASTERED, WATCHDOGS, SPLINTER CELL and just office work
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I’m looking at a custom build I came across
1) Ryzen 7 2700 R9 270 16 GB RAM
CPU - AMD RYZEN 2700 (8 Cores 16 Threads)
GPU - Sapphire Radeon R9 270 (Refurbished)
SSD - 128GB SAMSUNG
HDD - 500GB Western Digital (7200RPM)
RAM - 16GB 3200 MHz Micron
OS - Windows 10 Pro
COOLER - Snowman Titan ( 4 Heatpipe RGB Cooler )
Power Supply
Silverstone 750W 80+ Gold
Scythe 600W 80+ Platinum
530W 80+ Gold
MotherBoard
MSI A320M-A PRO
MSI B450-M PRO MAX
GIGABYTE B450 DS3H
MSI B450 PRO VDH MAX
ASUS PRIME B450M-A
Which mobo and PSU should I choose or is there anything else I should change ?
https://linustechtips.com/topic/1280641-custom-pc-build/
Change the CPU for sure. Why the much older 2700? Best would be to go for the R7 5800, but since it is not available.. ahem.. then look for the 3000 series equivalent.
Wait. The R9 270? It wont run any of the titles dude! You need a new GPU
https://linustechtips.com/topic/1280641-custom-pc-build/#findComment-14298225
