Hello guys . I was playing cyberpunk for a couple of days and I wasn't so pleased with my fps so I decided to oc my GPU I used the gigabyte software to oc manually . I was running tests with heaven benchmark , I tried to go on 2100 MHz and I couldn't so I stopped at 2088 that my card runed smoothly .
So I was ready to play and see how many fps I would achieve more. (My goal was 10 fps ) . So when is started the game the rendering was aufull I could see noise and particles on the glossy objects. So I reset to default all the settings on my GPU I reinstalled the latest drivers from nvdia and still I have the same issue when playing the rendering is bad as hell. I tried other games in some of them I am good and no such issue . Also ok the heaven benchmark when I runned it again with no oc I had the same particles on the ship that's floating on the canons.
I think I just broke my GPU... I hope the photo that I am attaching is clear so you can see what I mean .
GPU: gigabyte gtx 1080 g1 gaming
CPU: Ryzen 7 1700x
Ram: 16gb
https://linustechtips.com/topic/1280470-problem-rendering/
