My PC : ryzen 5 3600
msi gaming max
gtx 1060 6gb
3200 mhz corsair vengeance
250gb ssd wd blue
1 tb wd blue hdd
1 tb ( some laptop storage i needed in a pinch and never removed )
Current Fault- when trying to transfer data from an sd card (photos) to my pc i get an error that device is not connected all my fans flash white and computer freezes for maybe 5 seconds. i had a similar issue when playing rocket league on a controller when it was plugged in if i moved it it would freeze the screen completely ( turning monitor on and off didnt fix it or force closing it the app from my second monitor didnt work ) could this be a usb issue or is it a hardware or sofware thing ?
thank you in advance for any help
Edit - works in the back usb (motherboard usb slots )
https://linustechtips.com/topic/1280316-need-help-troubleshooting-freezing-error/
msi gaming max
gtx 1060 6gb
250gb ssd wd blue
1 tb wd blue hdd
Does this happen with different USB ports or just one?
If everything works fine with motherboard USB-s that should narrow the problem.
The thing is you can't do much. It could be faulty USB header on motherboard, or maybe even bad USB port. Best thing you can try is updating BIOS and changing USB header to another one if available.
Athlon x4 840 @3.7Ghz MSI A68HM-E33 V2 8GB DDR3 1600MHZ SC GTX 750TI A400 120GB TOSHIBA 1TB MSI 200W
