Title says it all.
I know the H100i can use corsair connect, but I'm more interested in the actual numbers.
-Shrimp
Gaming PC: CPU: 4770k @ 4.0Ghz GPU: Gigabyte G1 Gaming GTX 980 RAM: 16GB Corsair vengeance 1600Mhz Mobo: ASRock Extreme 9/AC PSU: Corsair AX760i Case: Corsair 750D CPU Cooler: Corsair H100i HDD: Samsung EVO 250GB, 1TB HDD, 4TB HDD
H110 is slightly thicker, so it'll cool a bit better. W/stock fans and 100% fan speed at high loads, the difference is less than 5C and usually closer to 1-3C.
The H100i is quieter at lower RPMs and loads while, if I remember correctly, the H110 cools slightly better.
The H110 would perform better at the same fan speed because of the higher surface area. I would recommend buying better fans for the H110 though. If you're not willing to spend more money for fans, I'd just go for the H100i. It's only a few degrees warmer.
https://docs.google.com/spreadsheet/lv?key=0AlPSGh26Ne0XdHZweHoxckRqazBvM0RTMW5GSFZNRmc#gid=0
"And yet my mind is screaming, provoked in an icy sweat. It’s pleading and begging for a release, scraping the walls of a padded cell, pounding hopelessly at the floors that won’t even deliver the gift of pain."  - Why I Don't Dream Anymore
