I have already reseated the ram. Trying single channel and dual channel. No boot still. Need help. I also had a previous post about this on another motherboard the ASUS ROG Crosshair VII Hero.
Could it be a CPU problem or still a ram problem?
https://linustechtips.com/topic/1280137-dram-light-illuminated/#findComment-14294695
Could potentially be a problem with the CPU's memory controller.
Do you have other ram to test with, maybe a spot check from a friend's PC?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1280137-dram-light-illuminated/#findComment-14294697
I did try out some some other ram.
One is the lpx 8x2 3200 and other one is the corsair rgb 16x2 3600.
I have also tried the cpu in another motherboard. Crosshair 7 hero, asus tuf b450 and then this one aorus b550.
On the crosshair 7, I get a 7A error and after awhile, I get an error 55. On the ASUS TUF, I get no post or error or anything, just doesn't boot up...
https://linustechtips.com/topic/1280137-dram-light-illuminated/#findComment-14294750
Well, if the CPU in either board is not working with either memory, you may be the unfortunate owner of a defective CPU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1280137-dram-light-illuminated/#findComment-14294754
Welp that's sad news :// btw, any PSU recommendations for 3900x + gigabyte windforce 2070s? And what would you do if you have a defective CPU? 😂
https://linustechtips.com/topic/1280137-dram-light-illuminated/#findComment-14294757
Buying in the united states?
Consider this:
https://pcpartpicker.com/product/CdLypg/rosewill-power-supply-capstone550m
If you aren't within the return window for the retailer you bought it from, contact AMD with the serial number in hand.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1280137-dram-light-illuminated/#findComment-14294759
