Hi all,
I have been facing a new problem on my desktop computer.
Basically, yesterday, I came home and when I turned on the computer, it just lighted the LED's and started the fans but there was no video output or connection to the keyboard or mouse (the LED's on the booth were turned off).
I tried to test only one RAM than the other than each RAM socket on the motherboard and then disconnected the graphics card and connected it again. None of these actions solved the problem. Disconnected all the cables, including power, for some hours but nothing. Then Disconnected everything again during the entire night but when connected the power cable and tested it this morning the result was the same.
After my lunch, I tried to do a video about this, to show to my job costumer that I can't work right now cause of this problem, but, on the moment I started filming, the computer turned on as usual and now it's working again
The only difference is that now, instead of showing the MSI motherboard picture on boot, it shows this screen that I will attach on the topic...
Anyone knows what this could be? I am afraid this will happen again!
I thank you very much for the help!!
https://linustechtips.com/topic/1279947-startup-problem-i-cant-understand/
BIOS got reset, you can turn on the MSI logo again in the BIOS settings if you want.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
