So I wanna buy a "Gigabyte GeForce® GTX 1660 SUPER™ GAMING OC 6GB" GPU and idk that the Motherboard and PSU is compatible, btw this is what I have:
Case:
Deepcool TESSERACT BF ATX Mid Tower Case (300mm case space | GPU is 280mm)
Motherboard:
GIGABYTE GA-H110M-DS2 v1.0
CPU:
intelcore i5 7400 @3Ghz
GPU:
GIGABYTE GTX 1050 2GB
Cable:
dual PCIe 6 pin +2pin cable
RAM:
2x Crucial 8GB DDR4-2400 UDIMM "CT8G4DFS824A"
PSU:
Chieftec. (Idk what type I have, because its already built in but the lowest Chieftec do 350W)
Monitor:
Philips 193V5LSB2/10 LED Monitor, 18.5", 1366x768, 5 ms, 16:9, 60Hz, VGA, VESA
Btw I want to run Escape From Tarkov and this game need some VRAM and RAM.
https://linustechtips.com/topic/1279430-compatibility-pls-help/
Just now, ComputerBuilder said:
If its cheiftec, switch out for a bronze 505 or higher, just ugrade the cpu to a i7 7th gen. and if avavlible, get a gpu like a rx480 or 580
I think his GPU is the main thing that needs upgrading rn.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1279430-compatibility-pls-help/#findComment-14289245
2 minutes ago, ComputerBuilder said:
i7 7th gen
sure, if you want to spend upwards of 300$ on the 7700.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1279430-compatibility-pls-help/#findComment-14289253
yes, but psu as well because a fucking 350w isn't going to work on a 1660 super, 6gb vs 2gb, much faser super
It could probably work, also a 7700k with a 1050 is REALLY unbalanced.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1279430-compatibility-pls-help/#findComment-14289254
BUT THE PSU ISNT A CPU. He meant that he needed to do a gpu, not cpu.
and they cost like 300usd. and are slower then the r5 3600 in games, for the same price as the 3600 and a mobo.
Bios database
prior build:
https://linustechtips.com/topic/1279430-compatibility-pls-help/#findComment-14289255
do you guys think that a i5 7th gen s going to work, it will work buts gonna be like a i7-5th gen
A 7th gen i5 will work. It's not great as it's 4c/4t but it will get the job done. A GPU upgrade will benefit him much more (a 1660 super for example)
geometry is hard
b550 > x570
https://linustechtips.com/topic/1279430-compatibility-pls-help/#findComment-14289273
Yeah my CPU is fine, running at 80% when in playing Escape From Tarkov on Reserve (biggest map).
The CPU effects the loading time what is perfectly fine.
I need the GPU because there are huge lag spikes and 2GB isn't enough for the lowest possible settings too.
Btw I have only 8gb ram which is runs at 7,5 sometimes 8gb. And I'll buy a matching 8gb RAM to run smooth.
https://linustechtips.com/topic/1279430-compatibility-pls-help/#findComment-14289548
