Budget (including currency):  £600 GBP
Country: United Kingdom
Games, programs or workloads that it will be used for:  Games (Assassins Creed  Unity,  Watch Dogs 2  and a few other small games ) , programming (pycharm) , light CAD
Other details :
Current Specs Considered:
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  with Wraith Stealth Cooler
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard
Memory: Crucial 16 GB (1 x 16 GB) DDR4-2666 CL19 Memory
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($59.00 @ Amazon)
Video Card: Gigabyte GeForce GTX 1650 4 GB OC Low Profile Video Card  OR   ZOTAC GAMING Geforce GTX 1650 OC    IF IN STOCK
Case: Corsair Carbide 175R RGB ATX Mid Tower Case
Power Supply: Cooler Master MWE White V2 230V 400 W 80+ Certified ATX Power Supply
Operating System: Microsoft Windows 10 Home 64-bit
Monitor: BenQ GW2283 21.5" 1920x1080 60 Hz Monitor
Apparently everybody decided to build a pc now so GTX 1650 graphics cards are out of stock
Is this a good combination of parts? Is it suited for what I would use it for?
 any feedback would be appreciated
https://linustechtips.com/topic/1279357-first-pc-build-what-do-you-think/
Other details :
Hi. I just finished building a pc of this budget for someone in the UK too. It's not easy right now due to availability. I had to get the gpu on ebay for example. It was used and i paid about RRP for it.
Your build looks fine and you'll be able to play your games albeit with lower than max settings. However I went with a Ryzen 3100 instead of a 2600 as it seems to match or outperform the basic 2600 in most games. I have a 3300X on backorder so I'll swap it into that build if I ever get it.
Motherboard is same as I used, decent board for the money.
Avoid single channel cl19 ram, it's just not worth it. Go for 2x8GB CL16 at least 3000mhz, preferabley 3200mhz Eg. https://uk.pcpartpicker.com/product/sn38TW/pny-anarchy-x-16gb-2-x-8gb-ddr4-3200-memory-md16gk2d4320016axr
Storage is fine but you can get 500GB of SSD storage for less than that. There's very little difference in game loading times between an SSD and an NvME M.2
GPU is okay but ideally you would go 1660 for the extra 50% vram it'll really help in your games.
Go for a 500W PSU
You'll regret not getting a 24 inch monitor. Any 24 inch with 1ms response time would do
I will recommend something like this instead...
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor (£132.84 @ CCL Computers)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard (£69.98 @ Amazon UK)
Memory: PNY Anarchy-X 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (£56.16 @ CCL Computers)
Storage: Pioneer 512 GB M.2-2280 NVME Solid State Drive (£55.67 @ Amazon UK)
Video Card: Sapphire Radeon RX 580 8 GB PULSE Video Card (£100.00) Get it used from sites like eBay and AliExpress. They usually go for around £100.
Case: KOLINK STRONGHOLD ATX Mid Tower Case (£38.99 @ Currys PC World)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply (£69.95 @ Amazon UK)
Monitor: LG 22MK430H-B 21.5" 1920x1080 75 Hz Monitor (£89.97 @ Laptops Direct)
Total: £613.56
Generated by PCPartPicker 2020-12-10 14:50 GMT+0000
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
