My new/used wall mounted PC
lexidobe
Hello everyone, I just built a wall mounted computer out of used parts I had laying around and I am wondering what you think of it.
I built this computer as an early Christmas gift for my disabled grandma because she needed a decent computer and doesn't have money to build something modern and expensive, so I built her one out of parts I had laying around since I am a bit of a hoarder. She doesn't need an ultra powerful gaming system, just something that will browse the web, play videos, and run basic online games reasonably well. So here's what I came up with:
CPU: Intel Core 2 Quad Q6700
Motherboard: EVGA 790i Ultra SLI
RAM: 8GB mix and match DDR3
Storage: Sandisk 120GB SSD
GPU: XFX R7 240
Power supply: Corsair HX750i
OS: Windows 7 X64
The only changes I plan to mount the PSU to the wall too and I may add a DVD drive so she can watch movies on it, but other than that it runs great and serves its purpose perfectly fine. Here's a pic of it. Questions and feedback are welcome as always! 😀
If you do get a DVD/Blu-Ray/HD DVD(?)/Blu-Ray+HD DVD (LG GGC-H20L) drive, make sure it has the tabs so the disc doesn't fall out.
Otherwise, good job!
elephants
That is a great point, thank you for the suggestion! Would the drive work okay sideways or should I mount it right side up?
