30 minutes ago, patken007 said:
ok thanks, but anyway i can improve my temperature
Change cooler, tune fan speed change thermal paste if you're using pre-applied or it's been a while (2 years maybe)
U can also open your side panel to see if case airflow is bad
If it drops more than 5c, your case airflow is not great, if more than 10c then it's definitely bad
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1277671-temperature-question/#findComment-14276354
