Hello,
recently i got stutter in all of my games..,
i tried everything...
reinstall windows - nothing
reset BIOS - nothing
disable HPET - nothing
emptystandbylist - nothing
remove all things in pc and build it again - nothing
dont start MSI afterburner + RTSS - nothing
tried other gpu - nothing
CPU: RYZEN 7 2700 @ 3.9ghz
GPU: GTX 1650Super (OC)
RAM: 2x8 3200 cl16 VIPER  (DUAL CHANNEL)
mobo: b450 Aorus Elite
SSD-256gb SYSTEM
hdd-1tb, 0,5tb, 250gb GAMES
PSU: coolermaster GX 550W 80+ bronze
monitor : 1) Philips 226VL 60hz
2) AOC 24g1 144hz
i builted this PC myself a year ago and it was not stuttering at all...
PLEASE HELP
https://linustechtips.com/topic/1277529-help-with-lagging-pc-ryzen-7/
Recently I've come across multiple threads about similar instabilities
Lets say... 4 Ram slots.
2 sticks.
4 labels for 4 slots, ABCD or 1234, BUT.... It can also be ACBD or 1324, and usually by mistake and re-swapping to appropriate slots per dimm, stuttering was removed, memory speeds were more compatible.
Just something to check in the manual or online,..as it's weirdly specific to random boards because not all follow the same 1234 slot layouts causing griefs.
Hope you get the help you need..
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
2 sticks.
i allready checked manual and i got them in right slots, even triend 1 and 3 slots , now i have 2 and 4...
