Hey, I have a laptop called the dell g5 5500 its great plays anything maxed... also with the fans maxed at dumb 80c gpu and 97 cpu while playing light titles like. trackmania (epic games store) crossout and even tf2 I dont know how to take apart computers never have done it and dont want to open it up. any software fixes? rn Im running it at the base clock of 2.60ghz so it wont run loud while watching : ) linustechtips 4K videos.(temporary fix) Please help It shut off couple of times too...
(I dont want to open it, maybe bios or intel chip tuning? Yea
https://linustechtips.com/topic/1277334-g5-overheating/
undervolting your cpu+gpu or running them in "economic" or "power saving" will decrease temps, as they are running with less power, note this will decrease performance.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14273992
Does throttle stop work? for that?
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14273995
possibly, I'm not familiar with throttle stop and its settings though.
AMD blackout rig
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14273997
Note: Does work! Thanks for solving my issue but bad thing.. I cant use it for gaming look at the ghz
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14274004
It'll boost up in games, run one and see how it handles
AMD blackout rig
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14274006
8 minutes ago, RTX 2070 Max-Q said:
Give me 15 mins
OK, Tested it well when I went to game Yes it did go up, but by a uh (2.5ghz and 70fps with 40fps sometimes) is there anyway to improve the ghz with staying in the no heat zone. 2.8-3.0ghz?
EDIT: Fixed it, TYSM I have had this issue ever since I got this laptop for a year trying to trouble shoot it
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14274012
No problem! have a good one!
AMD blackout rig
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14274038
  • 1 month later...
Wait what exactly did you do to fix it cause I have the same issue. With turbo boost off in throttle stop makes the performance crappy. I have the 10750h with the 1660ti
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14378342
I use throttlestop Speed shift - EPP 98
3.5Ghz @ 89c
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14387464
3.0ghz when I am watching youtube
https://linustechtips.com/topic/1277334-g5-overheating/#findComment-14387469
