This is with a 10600k, which admittedly has a slightly higher clockspeed and built in security mitigations than a stock locked 8700. (4.3ghz on the 8700 vs 4.5ghz on the 10600k, all core).
I'd say within a few % of this result is what you might expect on your 8700, maybe 10-15% given you're limited by memory speed as well.
I am going to consider this to be pretty much representative of what I'll see on my 5ghz 8700k once my 3080 comes in.
I would say you're probably fine in most games at 1440p.
Personally, unless you're going to be playing at 1080p, I'd just keep what you have.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270404
4 minutes ago, Jnys said:
I have my 3080 in my my right now. The thing is that im not so educated in this area. So idk what to do
You are not going to have terrible problems, but I would recommend getting a new CPU not long after getting the 3080.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270421
See above.
In practice, it likely won't be a meaningful difference in most games at 1440p, especially not a $600 one.
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270424
5 minutes ago, Jnys said:
Ok. The only thing is that it's a non k cpu.
Stock 10600k has 200 more mhz, slightly better thermals, more built in specter mitigations, and in this test, fast RAM. They are the same IPC.
Those are the differences, and with (or without, since we know a locked 8700 is faster than a Ryzen 5 2600 by a fair margin) enough to hit GPU limitation at 1440p.
Is that difference (if its even necessary) worth $300 (CPU) + $150 (motherboard) + $80 (RAM)?
Even assuming performance is as poor as the Ryzen 5 2600 (it isn't) is that worth it?
Since you already have the 8700 and 3080, what games are you playing, what resolution are you playing at, what refresh are you playing at, and is it reaching the performance that you want?
Are you having poor GPU utilization a lot?
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270434
if you are upgrading the ram either way i'd say 5600x, but it's not urgent at all.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270438
Im playing at 1440p 144 fps. I play rdr2,The new cod,Snowrunner, Doom eternal. And i am looking forward to play Cyberpunk 2077 next week (if it acctually launches this time). In cod i have like 100% cpu all the time while gpu is at like 40 to 80%
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270456
RDR2 isn't going to hit high FPS either way. COD - it might, but i don't think the 8700k is going to be a problem for 144fps. CB2077 is likely going to be mostly GPU bound, especially if you turn on ray tracing. DLSS will help with framerate as well.
Try it first and see if it meets your expectations.
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270502
I saw a guy hitting like 190 fps with a better cpu then me in cod with better settings. Meanwhile im at 110
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270508
What resolution and what settings?
Slow memory can be a part of that, too.
I suppose if you're going to upgrade the RAM as stated above, you should redo the whole thing and keep that system together. Although I'd consider that more of an oversight on the original setup.
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14270513
1440p max settings dlss performance. Wdym oversight? What do you mean with keep the system together?
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14271303
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14271312
I personally wouldn't have paired an 8700 with 2400mhz ram or a B360 or w/e, because you still can use faster memory and tweak power limits on a Z board -
If you're going to be buying new RAM, just buy all three and either retain the 8700/2400mhz/b360 and keep it as its own system or sell it off as a unit instead of parting it out
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14272810
Alright i bought a 3600 mhz kit to pair with the z370 to see if it get's better. It's nearly impossible to get a hold of a 5600x so i just thought that i might as well hold off on it until it's in stock. By that time i will also have more cash:)
I bought theese:https://www.amazon.com/gp/product/B0199STG76/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14273413
You'll probably do well with it. Make sure to go into cpu power and remove the power limits
https://linustechtips.com/topic/1276847-cpu-for-3080/#findComment-14273525
