Hey, I was wandering I just got my new g5 (dell) I noticed over my old g3 Woah! WAY bigger charger it was 240w, Could I put this in to my older laptop (its the 2019 version I bought it at the start of 2019, I decided I needed an upgrade from the GTX 1650 to a RTX 2070 Max -Q) Could I? The old charger is half as big as the new
https://linustechtips.com/topic/1275988-charger/
On 12/3/2020 at 3:51 AM, OrionFOTL said:
Sorry, I'm not really getting what you're asking about.
If you want to know if some charger is compatible with some computer, post detailed information about the charger and the computer.
mk
https://linustechtips.com/topic/1275988-charger/#findComment-14269747
